Blue Smart IP 22 / Permanent Conection with Battery possible
I’m using the BSC IP22 12/20(1) to charge the LiFePo4 on my boat. I’m wondering if it’s possible, to leave the charger connected to the battery all the time or if it’s necessary to use a relay to cut the connection, when no shore power is available?
Iow: Will the charger survive permanent connection if the LiFePo4 is charged via DC/DC-Charger or via solar power?
Thanks in advance for suggestions,
uli
Hi, that should not be a problem. There is a recent discussion on this topic which may prove useful to you.
Best of luck, Tony
