BETA: Connect your Electrical Vehicle to VRM
I am not able to get my 2025 Skoda Elroq linked correct - Any body with a Skoda ?
The VW ID.3 drooped the VRM connection a few days ago and since then no way to reconnect again.
I disconnected the car and went through the ENODE connection process and everything seems fine, it gets connected the car is identified but does not show up in VRM. The payment interface has not shown up when reconnecting.
It has been working for several months without issues.
Any clue what’s happening?
The Cerbo is on V3.80~27
Thanks in advance
I have tried once more - Now i am able to connect
And work with the data in NodeRed :wink: Nice
Looking forward to do some more testing
BUG?
VRM ID: 707441
Charging a car not linked - It still says that it is charging my Škoda Elroq not “unknown vehicle”
  • It shod see in vrm - that Device is Charging State = Not charging
    -After first or second update from the car, and switch vehicle to “unknown vehicle”
Hi all,
I want to thank you again for all of your feedback during the beta testing of the vehicle integration. I hope you’ve liked the feature so far. I just wanted to inform you that now on Beta VRM we have rolled out a new feature related to the vehicles. You will now get a push notification when the car SoC is under 50%, your house battery is full and there is excess solar so that you know you can start charging your car.
Hi @HenrikB ,
Thanks for reporting this! It does indeed look like a bug, affecting sites with only one EV linked. We will look into a fix as soon as possible!
Kind regards,
Lucian
Hello Team Victron,
Are you planning to deploy this feature to production soon ?
Is there any way that we can adjust the percentage of the car, when we want to receive a notification?
George
Hi George,
For now not, but we will work on this in the future.
Hi @HenrikB ,
We have deployed a fix for this bug onto the BETA VRM environment. Could you please check again if the matching behavior is correct?
Thanks!
Kind regards,
Lucian
Charging “Guest EV” via Victron EV charger – OK
Charging “Skoda” via Victron EV charger – does not change from “Guest EV” when last contact is updated – waiting a bit longer –
After 15 minutes of charging it says “Škoda Elroq” – this happens 5 minutes after the last update is made – OK - Fine for me.
Not tested charging “Skoda” with an alternative charger, and charging “Guest EV” with Victron, since both cars are already charged.
Today is say "Škoda Elroq" when charging the other car - now for 1H30M
The Skoda has SOC 81 % - target 80%
Has charged the other car Auto and MAN - still say Skoda
I had my Volvo C40 linked to VRM, but it stopped updating location data about two weeks ago. Everything else was working fine at the time. I have since removed the link and tried to reconnect the Volvo, but now it won’t connect at all. What should I do?
Hi @HenrikB @anttivaan ,
Thanks for reporting incorrect behavior. I will investigate the claims and respond to them as soon as possible!
Have a nice day!
Kind regards,
Lucian
Hi @HenrikB ,
Was the Skoda charging right before the other car started charging?
Kind regards,
Lucian
Hi @anttivaan ,
You can re-link your Volvo C40 by selecting “Volvo” under the “Linked account” section and selecting your EV from the dropdown.
Kind regards,
Lucian
I managed to reconnect it now, and the car is visible in the VRM. Thanks.
Hi @lucian Yes, I think so. What delay should I try when removing the Skoda and connecting the other car — 5, 10, 15, or 30 minutes — for testing? I can try this afternoon or tomorrow.
Normally, I unplug the Skoda and connect the other car within 1 minute to make the most of my solar energy.
PS: Maybe you can use the status information from:
Skoda
  • “Not charging”
  • “Last contact”
EV charger
  • “Charge time”
For example:
If ChargeTime.start < last_update.timestamp and Charging state = "Not charging", then set vehicles = "Unknown".
Hi Henrik, thanks for confirming!
Please try a 10-minute gap between unplugging the Škoda and plugging in the other car — detection works on a ~5-minute window, so 5 would sit right on the boundary. If you also do your usual <1-minute swap afterwards, that confirms the failing case for us too.
Your ChargeTime.start / “Not charging” suggestion is a good detection rule — I’ve included it in the internal issue for the quick-swap bug. Thanks!
Hi @Lucian
VRM: 707441
08-07-2026 CET time (EV charge station Mode Auto)
10:25 Unplug Škoda - Has reach 80% SOC
10:35 plugging in the other car “Guest EV” on web page
10:50 Unplug other car
10:51 web page “EV Disconnected”
11:00 plugging in “Škoda” Set to 90% SOC
11:01 web page update from no info to “Guest EV”
11:06 web page update from “Guest EV” to “Škoda Elroq”
11:31 Unplug Škoda - web page “EV Disconnected”
11:32 plugging in the other car “Škoda Elroq” still on web page
11:37 web page update from “Škoda Elroq” to “Guest EV”
11:49:30 Unplug other car
11:49:45 plugging in “Škoda” Set to 90% SOC
11:51 web page update from no info to “Guest EV”
11:56 web page update from “Guest EV” to “Škoda Elroq”
11:58 Unplug Škoda
11:58:15 plugging in the other car
11:59 “Škoda Elroq” still on web page
12:01 Webpage widget stop displaying Charging on the Skoda
12:03 Other car is “charged”
12:04 Setting Other car to 90% SOC
12:05 Webpage say “Škoda Elroq”
12:07 NodeRed is changing to (EV charge station Mode Manuel 24A) due to high SOC of house battery
12:15 Charge time 15 Min - still asy “Škoda Elroq” while the other car is charging.
12:20 Charge time 20 Min - still asy “Škoda Elroq” while the other car is charging.
12:25 Charge time 25 Min - still asy “Škoda Elroq” while the other car is charging.
Yes, it seems that a quick switch every now and then can register the wrong vehicle.
If I’m going to do further testing,
I’ll probably need a lower SOC on the cars
– set it to Manual mode 6A, and maybe find a single-phase cable. :wink:
