Best way to monitor 2 lithium batteries connected in parallel?
I would like to monitor two lithium batteries connected in parallel on my boat. Do I need to provide a Smartshunt IP65 for both batteries or just one Smartshunt for the entire battery pack?
Thank you for your advice.
Louis
If the batteries have bluetooth enabled BMSs inside then you can see they are both OK, then you need only 1 SmartShunt. If you have a GX device then you should only have 1 shunt for the whole battery bank as the GX device can only use 1 shunt for the controlled battery bank.
Thank you very much. So I think that I should monitor with one smarthsunt for each one to get the max security on Lifepo
