I’m building a small single battery sysem to support radio equipment. I’m using a Lifeo4 battery 12V 100A Deep Cycle I don’t see a selection for that type of battery on the charger/connect What should I select ? The preset seems to be at correct perameters or close Any suggestions? Thanks
Duffster
Typically at 12V, the charging parameters are close enough to VRLA for a Lithium battery. However, you can use VE Connect to customise these for a closer match.
Thanks Mike
