Battery monitor
Hi
Would it be possible to use the victron battery monitor to connect to a dash cam battery pack (BP-8000), if it is how would I connect them,
Thanks
MELenium
@MELenium What loads do you want to monitor? If they are dashcams which run off 5V, then no, as the it rated 6.4 - 70V and the elsewhere it makes no sense as the BP8000 will disconnect from the vehicle supply when the ignition is off if my understanding is correct which would effectively disconnect the shunt.
Thanks ejrossouw
You are probably right about the voltage, the battery when the igniton is turned off, it then goes into parking mode automaticaly so the battery is still working if that helps.
MELenium
