I have (4 ) 12v LiFePO4 100Ah batteries in my RV wired to a Victron smart Solar controller. It has worked fine in the past, but now it will only
charge the batteries to 12.3v to12.5 v then goes to float. I currently have the Rv disconnected from the battery bank and have victron smart charger hooked up. It is bouncing from bulk to absorb in 5 second intervals.Are the batteries bad? Would all 4 be bad, or does 1 bad battery mess up the whole bank ?
additional info
Controller app says. 14.2 v batt.
Batt. smart Monitor says. 13.80v batt
Volt meter on battery bank. 12.35v
