AppKey ??? LORAWAN V.E DIRECT
Good morning,
Opening a Victron ticket:
Apparently I cannot record the direct V.E on VRM portal without it being connected to the GX device (Cerbo GX, Color Control GX, …) however it is specified that: the Victron Energy SmartSolar MPPT 75V 15 amp supports VE.Direct connectivity but only in USB as I understand now so my lorawan project cannot be done without appkey
This Victron VE.Direct LoRaWAN module cannot therefore work alone without having this secure key if I wish to integrate with the LoRaWAN server.
I am not using a GX device and I do not want to connect this module to the VRM Portal, but only to the TTN lorawan or shirpstack server.
Here is the information for my module:
Portal ID: 70b3d549948xxxxx
DevEUI: 70b3d549948xxxxx
JoinEUI (AppEUI): 70b3d57xxxxxxxxx
Serial number: HQ18xxxxxxx
Part Number: ASS0xxxxxxxxx
Could you provide me with the AppKey.
So that I can finalize the integration of this module into my LoRaWAN server, could you provide me with this Appkey private key
Has anyone ever encountered this problem because generally AppKey is provided with the product?
So remember to ask for your key on the VRM portal if you have a GX or recognized product otherwise you cannot have this key, which I do not understand is not indicated at the time of purchase and why not provide this key, which is always supplied with Lorawan products?
Thank you in advance for your feedback.
