I have the following setup for my veranda: a 12-volt battery, a SmartSolar MPPT, and several LED strings.
The LED strings consist of two copper wires with small glass droplets, each containing a tiny LED. The LEDs are mounted alternately (positive, negative, positive, etc.). When I connect them to DC power, they light up alternately. If I reverse the polarity, the other half lights up.
To make the LED strings usable, I route the output through a cheap inverter from AliExpress that converts DC to AC.
Now here’s the strange part: when I connect two strings in series, my SmartSolar reports a power draw of 7 watts. When I connect three strings in series, the controller reports a power draw of only 1 watt.
Leds are non linear components. They do not behave like a resistor. Instead they behave like a Zener diode with strong temperature dependance. Therefore you need a constant current source to operate them properly. I am using the Meanwell current sources for my direct DC light installation. Some know how description is here.
