i would like to be able to see data on total power consumption on a daily basis. where on vrm can i do that?
Dashboard → Installation data → set period to “last 30 days” will show the bar chart with precision “1 day”. Red consumtion, yellow pv.
thank you. i am learning. i just installed a system from scratch with all new cables. multiplus 3k, cerbogx, 2 different solar chargers, orion dc to dc charger. 7 inch screen. autogen start. 2 lynx distributors, rec abms. i built my own battery bank out of 44 calb ca100 cells for a 1100amp hour 12v setup. i am in the process of installing 895 watts of solar. all in my superc on a freightliner cascadia chassis.
@encantotom
I recommend playing around a little.
The button “System overview” can be changed to consumption, solar and grid giving details on that views.
Even more important is the page “Analysis” when debugging the behavior. Get familiar with the BMS-device graphs, especially highest and lowest cell voltage and parameters CVL, CCL to understand behavior of your BMS in conjunction with Victron DVCC.
