Hello, two days ago I updated to version 3.50 on my RaspberryPi. Now I wanted to try out a few things with node-red on my test system and install the dashboard nodes or the UIBuilder. Unfortunately, neither worked. I got the following error message:
2024-11-02T12:41:27.246Z Installieren : node-red-dashboard 3.6.5
2024-11-02T12:41:27.094Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-dashboard@3.6.5
2024-11-02T12:41:29.262Z [err] npm warn config production Use --omit=dev instead.
2024-11-02T12:41:49.236Z [err] npm error code EEXIST
2024-11-02T12:41:49.237Z [err] npm error syscall mkdir
2024-11-02T12:41:49.238Z [err] npm error path /data/home/nodered/.npm/_cacache/content-v2/sha512/cc/ee
2024-11-02T12:41:49.239Z [err] npm error errno EEXIST
2024-11-02T12:41:49.264Z [err] npm error Invalid response body while trying to fetch https://registry.npmjs.org/compression: Unknown system error -74: Unknown system error -74, mkdir ‘/data/home/nodered/.npm/_cacache/content-v2/sha512/cc/ee’
2024-11-02T12:41:49.265Z [err] npm error File exists: /data/home/nodered/.npm/_cacache/content-v2/sha512/cc/ee
2024-11-02T12:41:49.265Z [err] npm error Remove the existing file and try again, or run npm
2024-11-02T12:41:49.266Z [err] npm error with --force to overwrite files recklessly.
2024-11-02T12:41:49.280Z [err]
2024-11-02T12:41:49.282Z [err] npm error A complete log of this run can be found in: /data/home/nodered/.npm/_logs/2024-11-02T12_41_28_843Z-debug-0.log
2024-11-02T12:41:49.327Z rc=1
2024-11-02T12:42:45.303Z Installieren : node-red-contrib-uibuilder 7.0.4
2024-11-02T12:42:44.906Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-uibuilder@7.0.4
2024-11-02T12:42:46.839Z [err] npm warn config production Use --omit=dev instead.
2024-11-02T12:43:19.373Z [err] npm error code EEXIST
2024-11-02T12:43:19.373Z [err] npm error syscall mkdir
2024-11-02T12:43:19.374Z [err] npm error path /data/home/nodered/.npm/_cacache/content-v2/sha512/d5/cb
2024-11-02T12:43:19.375Z [err] npm error errno EEXIST
2024-11-02T12:43:19.407Z [err] npm error Invalid response body while trying to fetch https://registry.npmjs.org/@totallyinformation%2Fti-common-event-handler: Unknown system error -74: Unknown system error -74, mkdir ‘/data/home/nodered/.npm/_cacache/content-v2/sha512/d5/cb’
2024-11-02T12:43:19.408Z [err] npm error File exists: /data/home/nodered/.npm/_cacache/content-v2/sha512/d5/cb
2024-11-02T12:43:19.408Z [err] npm error Remove the existing file and try again, or run npm
2024-11-02T12:43:19.409Z [err] npm error with --force to overwrite files recklessly.
2024-11-02T12:43:19.423Z [err]
2024-11-02T12:43:19.426Z [err] npm error A complete log of this run can be found in: /data/home/nodered/.npm/_logs/2024-11-02T12_42_46_398Z-debug-0.log
2024-11-02T12:43:19.485Z rc=1
Do you have an idea why this could be?
Kind regards Ronald
