I have a an island system based on a multiplus 2 and AC coupled solar. The pv inverter assistent is enabled. I am only aware of being able to change frequencies and a voltage off set when to reengage pv inverters by changing frequency from -say- 53 to 50 Hz in case of overvoltage.
The system will keep 50 Hz until the battery is reaching 28.8V (in a 24V system) and only then starts to regulate towards 53 Hz. I would like to adjust this target voltage to a reduced amount, say 28 volts and cannot seem to find a means to do that.
I was told I could do that via VictronConnect, however when selecting the multiplus2 within I can only see the overview, when trying to access the preferences I am told to use the Mk3 device. I don´t have that but am using a Mk2.2 device which seems to communicate just fine. So bonus question Is there a way to enable VictronConnect access proper?
Cheers
