Why?
In New Zealand a 240V system on a boat has to be certified by an electrical inspector which complicates things because this inspection will also include the 12V system and can lead to expensive alterations which are not always practical on our boat. This could easily add another $5000 which is uneconomical. A way around that is to use only pre-wired 240V components which can be tested and tagged individually. A power pack like an EcoFlow would work well for the 240V equipment we use occasionally.
I am thinking of upgrading the old lead acid house battery bank to LiFePo which will power everything navigation/safety related plus the fridge. After that I want to add a 240V system which consists of a EcoFlow (4000W) for induction cooking, the odd power tool and maybe a hot shower and heater.
So basically:
Charging LiFePo house battery with DC-DC charger while engine is running.
Charging LiFePo house battery with solar panels while the sun is shining.
Charging LiFePo house battery with small pre-wired portable charger from shore power from time to time.
I want to charge the power station whenever there is left over power from the engine or the solar panels.
It would be useful to have an option to top up the house battery if the engine is off at night.
I would like always priority to the house battery.
Can I charge the EcoFlow e.g. from a DC-DC charger from the house battery? If I switch the DC-DC charger to on at e.g. 95% state of charge and off again once it falls below 90% of the house battery this would mean that all the power for the EcoFlow will be always routed through the house battery. Is this a concern for the longevity of the house battery?
Would it be better instead to have the solar panels connected to an MPPT for charging the house battery and then when 95% state of charge is achieved swich the solar panels directly to the EcoFlow inbuild MPPT? This way the current would stop running through the house battery but there is a risk for the integrity of the vital navigation system?
I am also not sure how to achieve good visibility of this system using a Cerbo GX.
