I am trying to access my node red install without logging in to VRM. I have tried localhost:1881, venus.local:1881, ip:1881 (and 1880 because google mentioned that one too)
Both SignalK and nodeRed work thru VRM…
https://192.xxx.xx.xxx:1881/
https://192.xxx.xx.xxx:1881/ui
ui for a dashboard if you have made one.
Try the ip address.
For what ever reason, typing it into the browser bar didn’t work, but I found the link in the remote console that let me get to it. Same was true for Signal K…
It should work locally with the IP, as long as you are on the same LAN & subnet as Venus.
