I have a quattro 48v, 10k. I am trying to choose between running my AC through it on 230VAC or running it directly off batteries (48VDC).
230VAC option has losses of the quattro (between 30% and 5% depending on temp and other loads.) 48VDC option requires specialist 48VDC compressor etc. Can be done but more work, more cost, etc.
Logic case A:
If the losses aren’t that high, and the Quattro needs some load if its on, maybe running it through the Quattro is fine.
Logic Case B:
Direct off 48VDC batteries is the most efficient and leaves more capacity available to be used in the quattro.
Opinions with some of your justification would be appreciated.
