When setting the Cerbo GX IP in the router, after a few minutes it gives an error and starts accumulating data on the Cerbo GX.The strange thing is that I can still see the information in real time from the VRM application but the data in the graphs does not appear.
I can also access through the remote console but if I try to check for updates it tells me that an error has occurred. And if I go to the VRM portal section it says that there is an error.
The way to solve the problem is by going to the WiFi section and selecting the WiFi you are connected to and setting the Manual IP, but this is a patch.
Greetings, I hope to help fix this bug. I have enabled remote access so you can see what might be happening.
