I have ordered 3xBattery Balancers to connect to my system.
I currently use 2x24v batteries in serial to produce a 48V system.
The included install instructions only detail a 4x12v batteries so could anyone confirm how I should connect the Battery Balancers to my 2x24v system please?
Don’t.
Depending on what type of batteries you have, keeping them balanced could have several different solutions, not including the use of “12V balancers”
Those should have built in balancing, but check with the manufacturer about series operation. some internal BMS systems can’t take the reverse voltage caused by switching off with series operation.
