So I noticed in VRM that my solar panel voltage/current chart vs battery voltage/current chart. That the batter current is higher because I’m guessing due to the conversion to the lower voltage. So does this mean if I use 24v system Solar panels that it would be higher voltage but the conversion to 12v that it would make the current even higher? So for example (yes, I know 24v panels are not 24v they are like 36v) 24v 400w panel should put out 16.6A but after conversion to 12v, would it be 33.3A? Sorry for the ignorance but just curious since 24v would work with smaller wires. I have a smart solar 100/50 running my solar.
Related topics
| Topic | Replies | Views | Activity | |
| Solar panels for 24v system | 3 | 245 | 8 April 2026 | |
| Newbie to solar question 24v or 12v panels - serial or parallel connection | 3 | 695 | 18 January 2025 | |
| 1 or 2 solar panels in a 24V marine system? | 2 | 30 | 24 May 2025 | |
| Solar panel voltages versus output | 3 | 279 | 27 February 2025 | |
| Advice for upcoming purchase | 4 | 95 | 28 July 2025 |
