Im having a hard time understanding where to connect the neutrals for split phase and what happens when the inverters internal relay connects thr ground and neutrals. I have split phase 240 shore power. I have a 3600w I.T. on each leg. Then I have a blue sea Blue Sea Systems, 8498, AC 3 Sources breaker panel. Then I have 2 sets of 2 24/3000/70s in parallel and series each set already feeds 2 separate 120vac panels. I want to add a 240vac appliance so I want to configure them for split pphase.please help?
ProjectTrawler
(John)
1
Wirl
2
Morning,
could you make a sketch? I think it’ll be easier to help then.
Thanks
Related topics
| Topic | Replies | Views | Activity | |
| Help with wiring 2 Multi plus 12/3000/120 units with auto transformer split phase | 8 | 337 | February 25, 2026 | |
| Victron isolation transformer wiring to US Split phase | 1 | 321 | July 3, 2025 | |
| Isolation transformer is flipping gfci on new install | 1 | 46 | October 1, 2026 | |
| Dual Multiplus balancing Diagram | 3 | 609 | May 9, 2025 | |
| Split phase 120/240 hardware | 5 | 1263 | November 11, 2024 |
