What is the best transformer choice to effectively and safely convert 120/240V (50A) split phase to 230V (32A) single phase shore power for a sailing vessel? Note that the onboard power must be 230V at 32A (>7kw), so the transformer rating will need to meet this requirement. Based on the transformer choice, please explain exactly how the input and output wiring will be connected. Thanks in advance!
Related topics
| Topic | Replies | Views | Activity | |
| Fitting the Victron Autotransformer and ancillary items required for US shore power | 3 | 107 | 6 August 2026 | |
| Victron isolation transformer wiring to US Split phase | 1 | 316 | 3 July 2025 | |
| Using 50amp isolation transformer with 30amp shore power | 1 | 60 | 8 July 2026 | |
| Wiring US 240/120 v 50 amp split phase to 230/240 v Quattro (ONLY needed to output 240 v) | 18 | 1164 | 21 January 2025 | |
| AT with 240V Quattro or Split Phase with Do not Switch as group | 2 | 186 | 27 November 2024 |
