What to buy
I have in series 10 100w panels 225v victron charge controller 250/70. I am installing another 1000w in parallel to give me just under 245v on roof. Im looking for a victron inverter to replace the renogy 2000w. Ideas?
245 is a bad voltage. To high for the 250 MPPTs and taking a RS is oversized.
Either remove one panel, take panels with lower voltage, or if already purchased, run them as 5 serial, 2 parallel string.
You should use the mppt calculator to play around with options:
