VRM Zoom Reset Button Placement
VRM advanced widgets use a library called highcharts, the location of the reset zoom button is drawn by highcharts. There is a method to draw the reset zoom button with some relative offset outside the chart area, but given the dynamic nature of the advanced page, on all screen sizes, all devices etc, setting. A fixed offset isn’t a simple thing and might make the situation worse for some other user.
I find personally the most issues on very small screens, because the button is relatively big. Almost never a problem for me on larger screen. So in those cases, I have just come to accept that if I am on small screen, the advanced widget page UX is not going to be optimal.
As more users move to smaller screens, there are many things in VRM that need to re-optimised, we have a project underway for this that may solve it.
The widgets already use settings and magnify pictograms. I see no reason why after a zoom there couldn’t appear a pictogram (striked through magnifier glass) to “reset zoom”. Complete outside the canvas, using highcharts builtins, trivial task.
or similar.
I am not sure if the library provides that capability. resetZoom allows for a position to be specified and an offset.
This seems to currently be: Align: Right (default) and offsets y by -10.
If a higher offset is used such as -30 or -40 it would move the reset button above the plot area.
Like so (from an example on their site):
I to find the positioning at times a little annoying, but it is not frequent enough to add it to the list of improvements.
Better than nothing. That here is a relatively safe real estate in the widget:
So yeah, that offset might just do the trick.
I’ll pass on the zoom fix to the developers so we can at least get it in beta for a while and see if it causes other problems or not
Hi Guy!
I postet last year in the german lanuage section this problem. But no Victron manager responded. Very helpfull is the timepointer which is synchron in all diagrams. But when you use it there is a little solid color filled circle in the crossing point. That circle covers small objects. Also a popup with time and Parameters covers the diagram:
Both cases are amendable: No solid circle but the timepointer should end short of the line in the diagram. The values should be placed in the head of the of the diagram. Now you can see the important jump to 100% in the left diagram. Like this example:
This change has been made in beta, should be in production soon.
Now i see the values in th upper part of the diagram in Beta. Perfect! Thank you
