VRM Remote Console - Missing Relay 2 switch
I’d like to know if the VRM remote console behavior is correct or not.
As you can see in the image below, the status of relay #2, which is configured on temperature sensor, is not visible.
In the picture below you can see both the settings for relay #1 which works correctly based on battery SOC, and the settings for relay #2 which runs some fans based on temperature.
I restarted the CerboGX many times hoping it would fix the issue, but had no success.
I don’t know what I am missing or maybe I found some kind of bug in the VRM remote console layout.
Any help would be appreciated
Kind regards
Enzo
I get the same, depending on the relay setting. Apart from the genset start / stop, the relay controls only appear when set to manual. Anything else, they disappear. This is not a function of VRM, but more GUI2,or venus itself.
