I have had great use of the VRM API pulling different data into NodeRed.
Every now and then I experience that the dashboard I have created displays strange data. I believe this has happened 3-4 times this year. I also believe it’s related to solution upgrade.
What seems to happen is that new data is added, and this change the ID needed to pick the right data. The data in this examples has recently been moved to ID 208 and 201.
I do understand the need to populate and change these data set, but request Victron to publish when you do so. Preferable with an overview of the different data element (maybe something like that already exist)
I am using API type installations and Diagnostics data for an installation
