ViMultiPlus 12/3000/120-50 120V VE.Bus
I have 2 Battleborns 100AH Lipo batteries, going to add a 3rd for upgrading to the VM+2 and wondering if the VM+2 will be under amped. I just read the instruction manual minimum is 400AMPS. The most will load on the inverter will be a Kuerig and the Microwave, inrush is not much over 1500. Am I going to have a problem with only 300AH, or should I stick to the spec, buy a 270 and parallel to the other 2 100’s? (*significant $$$$ uptick in Battery buy to a 270)
Also will end up with 800W up top RV of Rich Solar from 400…
Thank you for your support.
O1
