VICTRON 12/2000/80 Mk1 MultiPlus Compact Fault
Our inverter has stopped working
Can Anyone shed any light on this please? Or if you have any experiences with Victron Technical/Repairs.
It outputs 235v for 2-3 seconds, drops out, outputs 235v/drops out… constant cycle. Without any loads.
Any help welcome
Hi Javea,
Best to check your battery voltage, and battery cable connections. These need to be clean and tightly clamped. Any voltage drop will cause the inverter to stop.
Are there any LED light indications on the inverter when this happens?
