VE Bus BMS Charge disconnect
When the Charge disconnect output on the VE Bus BMS goes low this opens a charge relay and it could also disconnect an alternator regulator to protect an alternator from a sudden disconnection. Given that the charge relay and the alternator regulator disconnect at exactly the same time is this ‘too late’ to protect the alternator?
