Thx Grua, I missed that one.
Use GUIv1 ![]()
Hello
For sake of being meticulous, I tested some more:
- With DVCC Voltage Limit already active, setting the threshold works as intended both in GUIv1 and GUIv2
- With DVCC Voltage Limit disabled, enabling it and setting a DVCC Max Charge Voltage in GUIv2 of 57.6V, the moment I press “Set” it rounds up to 58V.
When I check the setting applied in the system in GUIv1 or a Node Red flow, it also says 58V.
This is where my initial “the system works with the rounded value” comment came from.
Setting a value of 57.6V in GUIv1 works as it should and the correct value is then represented in Node Red as well as GUIv2.
Funky behavior but a minor inconvenience since we still have GUIv1 and the fixed version is due shortly.
