Hi, I recognized an issue the last days.
When the new prices comes into the DESS system and it is decided to load the battery with a certain rate, this loading rate keeps constant, even if there is enough PV load available to load at higher rates. So the system cant use the full PV load until the desired SOC is reached …
I my case the system was loading the battery with 1,5 kW rate (3,5 kW is max) to reach the desired SOC within an hour, but there was 5 kW of PV load available and 3,5 kW were fed into the grid.
