TwinCAT ADS connection on Cerbo GX
Has anyone ever read TwinCAT 2 PLC variables at a Cerbo GX via TwinCAT-ADS in Node-RED? I tried `node-red-contrib-ads-client`, but it doesn’t work because there’s no ADS router running on the Cerbo.
Is there an easy way to do this without having to install external scripts or similar on the Cerbo?
It’s working—it was a configuration error! The correct procedure is described here:
https://github.com/jisotalo/ads-client/blob/master/README.md
Setup 3 works!
