A Victron video describing the Lynx distributor, points out the grounding point to be used. This will couple DC negative to ground i.e the same as AC ground. The instructions for my battery a BMX ESS X (10Kw) spcifically states not to ground the battery. No explanation why. Any views?
Related topics
| Topic | Replies | Views | Activity | |
| Grounding to chassis | 4 | 300 | 17 January 2026 | |
| I'm a little stuck on how I should ground to my van | 6 | 1193 | 30 December 2025 | |
| Grounding Quattro and Lynx | 0 | 83 | 19 August 2025 | |
| What's the proper way to ground/Earth a grid-connected ESS around the Multi RS 48/6000? | 9 | 818 | 10 September 2025 | |
| Can I mix AC & DC grounding? | 2 | 2164 | 3 September 2024 |
