The mechanical drawing of the 330 AH (BAT512132410) has at least one incorrect dimension
I recently downloaded the mechanical drawing for the subject battery from the Victron downloads page and used it as the basis for a Fusion 360 drawing of part of a battery box. As it turns out the dimension between battery posts, listed as 227 mm, is not correct. It appears to be closer to 219. Unfortunately I didn’t discover this until I started cutting material. Can you please correct and repost the drawing?
That battery has been discontinued for some time now (getting close to a year or so), so regretfully I doubt that correcting old drawings of it will get much priority in the scheme of things…
