I do have a strong oscillating installation and I cannot seems to get to the problem.
Installation information
System: 3 phase MP2 48/5000/70-50 230V (initially fw 552, later 555)
Batteries: 4x Pylontech US5000 (~19kWh)
DC: each battery with own pair of wires to Victron Lynx, 3 pairs 70mm2 to MP2’s
Controls: Cerbo GX (initially v3.31, later 3,54), wired ethernet
AC: only connected to AC in on 3x16A (system limit set to 13A, inverters limit @ 9000W)
Solar: to AC in, ~7kWp with 3 different systems. Measurements over ShellyEM’s to MQTT to Cerbo.
AC measurement: initially over Smart meter P1 and MQTT to Cerbo (1 sec update), later VM-3P75CT over modbus-UDP (100ms update)
ESS mode (with DESS)
Symptoms
strong change in ‘hum’ of inverters (with 0,5 Hz frequency), lot of changing/blinking of inverter led (because swing can be + and - 1000W). I cannot remember this behaviour after the installation (~1 year ago), but I am noticing it for about 6 months now.
Step 1 taken in trying to solve issue
Changed AC measurements to VM-3P75CT over modbus UDP
Upgraded Cerbo to 3.54 with factory reset
No change in situation. With the VM-3 data I was able to create the following graph:
These measurements are from the VM3 (upper graph) with the 3 phases and total power (blue). Settings Cerbo: Grid measurement, setpoint 0W. Solar still connected.
Step 2 taken in trying to solve issue
Upgraded MP2 to FW 555
Tried setup with 1 battery at the time
Disable DESS
Results: No change
Step 3 taken in trying to solve issue
Disconnected PV
Results: No change
Step 4 taken in trying to solve issue
Switched from external AC measurement to internal AC measurments with different setpoints + and -
Results: No change, system keeps oscillating
I am slowly running out of options. Sometimes the system seems to be stable but I cannot find a relation with anything (yet), I will add more monitoring to search for relations with other events.
If I am correct, the Cerbo sends setpoints to the MP2’s, so I am suspecting the Cerbo somehow. It might receive wrong readings or processes the readings wrong. Can anybode guide me how to troubleshoot the Cerbo’s behaviour? Do I overlook something or are there other things to research?
Any help appreciated.
Frank
