Split Phase- Faults When PE is Connected
Hello everyone,
I’m having an issue with my Victron setup and hope someone here can help.
Setup:
• I am running two Victron Multiplus II 5000 inverters in split-phase mode (one phase per inverter).
• Both inverters are connected to a common PE and N busbar.
• The system is based on a TN-C-S grid.
• AC-Out is not connected.
• Split-phase with 120-degree configuration has been set.
Problem:
As long as the PE connections of the two inverters are not joined, everything runs smoothly, and the inverters synchronize correctly.
However, once I connect the PE lines of the two inverters, they go into fault mode:
• Inverter 1: Error code 1
• Inverter 2: Error code 3
What I’ve tested so far:
  1. Both inverters work perfectly fine when operating individually.
  2. PE connections appear clean and low-resistance.
  3. Continuity and functionality of all relays have been tested.
Does anyone have any ideas on what might be causing this issue? Or any additional steps I could take to narrow it down?
Thanks in advance for your help!
Best regards,
DoubleCrunch
You don’t need to post the topic twice.
There is always the option of translation via the small ‘globe’ in the language window …
