Hi All,
I am planning to purchase three Victron Solar 215W-24V panels. I need a technical drawing / spec, which shows the size and dimension of the fitting holes, as well as their position inside the frame with distance measurements to the sides, etc..
I have looked at the brochure, the manual and the spec, but can‘t (seem to) find it. Also a little Google‘ing/Gemini‘ing doesn‘t help. These are being installed in a windy place (a boat), the frame for this needs to support pretty much all fixing holes, as per manual and the frame is being manufactured some distance away.
Thanks,
Thomas
