After waiting for the reseller to Have Time to look at it an RMA has been lodged & as its close to Christmas could take some Time
REPLY
The Quattro returned from RMA, and guess what? It’s all good! The internal cabling was reconnected, and there were no direct faults found. There’s a slight suspicion that the solar controller might have been the culprit, but I’m not sure how to explain that.
Anyway, I put the Quattro back into service, and it’s running smoothly without any issues. The wiring connections are the same as before, except I increased it to 50mmSq cable (still Orange with Red/Black Heat-shrink ends to identify polarities
50mm Sq Welding Cable
Used for welding power & switchboard applications. Consists of high quality copper wire stranding & has double insulation for better resistance in heavy working conditions.
Features
- Double Insulated
- Highly Flexible
- Meter Marked
- Abrasion Resistant Outer Layer
Applications
- Suiting Mine Sites
- Welding Generators
- Electrical Switchboards
Specifications
Application: For use with arc welding equipment rated in accordance with AS 1996. Suitable for glanding.
Conductor: Plain annealed coper (AS/NZS 1125)
Insulation / Sheath: Nitrile-Butadine-PVC Copolymer (TP-90, met RoHS)
Voltage: 0.6/1.0KV
Standards: AS/NZS 1995
|Part No|Nom Area mm2|Stranding No/mm|Nom. 0/D mm|Nom Insulation Thickness mm|Nom Sheath Thickness mm|Amp Rating 100% duty cycle|Amp Rating duty cycle|Amp Rating 3 duty cycle|Maximum Resistance at 20°C 0/Km|
|ZW50|50|1561/0.20|13.6|1|1.2|250|320|450|0.386|
Oh, and I also upgraded to a smart shunt, and it seems to be working great! It’s measuring the voltages and currents accurately.
