I am “Gog” - Going off Grid and am monitoring my upgraded battery - Freedom Won 40/32 800Ah
My Solar Solution:
1 x Victron Energy Quattro 48/8000 (Grid Tied – Single Phase)
1 x Cerbo GX with ESS for Self-Consumption
1 x Victron Energy RS450/100 Solar Charge Controller / MPPT
1 x 48V Freedom Won 40/32 Lithium-Ion battery
1 x Yamaha EF6600 Generator with 2 x 16A Out lets - not in use at the moment.
8 x 345W Sunpower CPV Panels, S -25.88, Azimuth: North, Tilt Angle: 30°
The ESS Assistant will be removed when I disconnect from the grid. Right now I am running in inverter mode.
On Thursday 14/05/2026 06:15, the SOC was 76%. I then created several loads baking some Panini, running a pressure cooker, vacuum cleaner and induction stove. At 14/05/2026 17:48, the SOC was 68%.
15/05/2026 06:15 - SOC = 49% MPPT Active for the first time on this day.
15/05/2026 17:47 - SOC = 58% MPPT - Off
16/05/2026 06:17 which the MPPT State became active, the SOC was 39%.
By 12:54, the SOC was 51%. By 13:06, the SOC was 100%.
Below is an extract from the logs: 51 - 100% SOC from 12:54 to 13:06.
Can anyone allude to what has happened here?
How often will this occur?
