Readings like this are often due to wrong wiring and on vehicles incorrect chassis ground. Have you got a connection from the batteries to the chassis. If you have then this should be on the load/system side of the SmartShunt, not on the battery. See the FAQ mentioned in the top sticky post of the DIY category.
Related topics
| Topic | Replies | Views | Activity | |
| SmartShunt showing 100% SOC when battery is not at 100% | 8 | 581 | 27 October 2025 | |
| Smartshunt Voltage Issues | 3 | 236 | 4 February 2026 | |
| Phantom currents with Smartshunt | 0 | 155 | 7 October 2024 | |
| Problems with the smartshunt | 10 | 934 | 2 February 2025 | |
| SmartShunt not recording all MPPT amps | 10 | 223 | 31 May 2026 |
