Smart shunts crazy readings
That looks to me to be bad data. Is the VE.Direct cable from the shunt to the GX running past any active gear that could be spewing a lot of RF? things like microwaves, poor quality phone chargers, ballast from fluorescent lights, that kind of thing.
Other things to try;
  • swap the VE.Direct cable. The signal rate over ve.direct is very low, and its a near bulletproof serial signal protocol that can run over almost anything, but there still could be a fault with the cable or someone jammed it in a door hinge or stuck a staple through it.
  • Change the ve.direct port on the GX
  • Victron shunts generally never need calibration, but maybe someone tried to calibrate it and completely messed it up??? (calibration is covered in the shunt manual )
  • sometimes relying on a chassis negative that looks fine but isn’t actually attached to the chassis can yeild strange results.
  • Do you have aluminium bus bars? weird results
  • Read @pwfarnell post here
