We have a small off-grid system with 2x100w solar panels, SmartSolar MPPT 100/20 and now 2*Lead Carbon 12v batteries in parallel (Expedition Plus EX12-160C). All has worked well for about 6 years, but this year we have had many unexpected load switch-offs. Initially we thought it was a problem with the old batteries, but having replaced those we are still getting the effect. Looking at the battery voltage information in the app, the voltage seems to “bounce” low then back up again every time a light (LED strip, up to 1A load) is switched on. See screenshot 175101 for example.
Further, we have a separate voltmeter across the battery, which was reading around 12.7V while the trends in the app were showing around 11.3V. “Rebooting” the controller (disconnecting from all power for 10 minutes) fixed this and also fixed the “bouncing” issue.
So, am I correct in assuming that the controller is going faulty and should be replaced? Is this a known failure mode?
Any advice on which controller to choose would be appreciated - I sized the original around the solar panels; but now we are interested in possibly adding wind generation, so there would be two different inputs - would that need a different type of controller?
Thank you
