Rover Boost and Victron 100/20 and 48v 150ah Humsienk LIFEPO4 battery
Beginner DIYhere. I have a Renogy 10A 400w panel (47.2v) and Rover Boost controller and was thinking of using the Rover to boost the Renogy voltage to beyond the 58.4v the battery needs to start charging it. Apparently though it looks like the rover can only accept voltage up to 40v so this may be incompatible. Would the 100/20 suit if I added an additional 12v 200w panel which has also 10A and combine the volts in series?
any other thoughts appreciated.
