Hy Community, i had bad winter days with mit Smart LiFePo4 Battery ![]()
I had my Smart LiFePO4 Batterie to long in my RV when it was around 0°C Outside. So charging was not possible.
Smart Shunt showed a SOC of ~15%, so that i was not in panik. But one day the Batterie did not came up in the Victron Connect App, so i opened the main batterie switch. Since conditions outside did not get better for 2-3 days, i took the battery inside my house and bought a Blue Smart Changer. (I read that it can charge theses batteries even from 0V). First Charging started at 10.52 battery voltage. Since i could not configure a Charge current below 5A in the Blue Smart Charger (wantet to charge with 0.1A first, as the manual recommends for undevoltage batteries), i hoped that 5A is also fine, since 10.52V did not looked SO bad.
I charged for some hours (with breaks over some days, since i needed to monitor it safely).
When i reached about 13V battery voltage and the bluetooth did not came back, i opened the battery to reboot the electronics, by disconnection it from + for some seconds. Bluetooth was back. I was able to monitor the Cells and they where surpisingly very equal (~3.29/3.3 V).
I added the sensors to home assistant, made an automation to toggle off the charger when cell drift is > 0.1V, cell voltage > 3.69V and battery tempetature > 45°C, then contiuned charging with 13.8V.
When i reached the Absorption Mode at ~13.8V, i changed the Charge voltage to 14.2V and the current to 10A.
My cell drift limit kicked in quickly, so i increased it to “> 0.2V”, then “> 0.3V”.
Then Cell 1 reached 3.66V and the Cell balancing started. Cell 2,3,4 balanced to about ~3.58V (+/- 0.01V), but cell 4 is now stuck at ~3.42(+/- 0.01V).
Now my Questions:
Is my Battery Lost?
Or can i continue without danger with one cell having a drift of 0.15V less then the others?
Is there anything i could try to also get this cell up? Give cell balancing more time?
How should i continue? Wait? Retry?
Did i made mistakes in the recovery process? (not starting with 0.01A but with 5A?)
If anyone is interested in the home assitant sensor templates, i can share them here.(of course if possible use the victron BMS) but the blue charge has no remote on/off terminal, so i helped me with this and a smart plug infront of the charger.
