Please fix my settings, 100% sync not happening
I can’t really tell from that picture because it does not show if the lower SoC threshold has been passed or not.
It is interesting to see that you basically sync on float. Maybe not a bad idea. It doesn’t harm I think and those few percent that you loose related to syncing on absorption… who cares.
Have it similarly, except I sync on 54.9, making sure that it only sync when it goes from float to absorption. Absorption hopefully happens at 55V….
I am going to double check that, I suggest you do too.
At any rate, we no longer have to stand by and watch our batteries deteriorate during enless absorptions.
It didn’t 64,3% was the lowest
Exactly this
Yes! At least someone can understand this.
9 months of the year, I have unending enough sun hours per day.
Absorbing at float is good enough. I don’t need the raised voltage; I understand people with limited sun hours can need that.
The other 3 months per year I’ll need to use the grid, either way, I’ll see it then…
