I don’t find any info of the max cable size. Where did you see that it can handle a 16mm2 cable? I don’t see it…![]()
They are normal miniature circuit-breakers in terms of design, just like in my profession … 16mm can easily go in there ![]()
Of course … Always as much as possible with the available space
Okay okay.
I believe you…daddy.![]()
(…your profession must be something like electrician?
Hello…huh???
Don’t mix everything up…I finally understand some parts of Steffens explanations.![]()
Morning🙃
Question: what are the pros and cons for my settings if I use 1 x 4 panel in series
4 x 23.9V = 95.6V
95.6V / 10.74A
…or if I use 2 x 2 panel in series/parallel
2 x 23.9V = 47.8V, 2 x 10.74 = 21.48A
47.8V / 21.48A
- I know that both needs different parameter MPPT controller
- I know that in series I reach the 5V extra voltage earlier to start the MPPT
- I know that the shading has bigger affect on panels that connected in series
- I know that if the short circuit current of the array is greater than the ‘maximum series fuse rating’ listed on the panel’s sticker then MC4 fuses must be used on the + right before the cable splitter
What else should I consider?
You could open a new Thread for this new Question ![]()
maybe with a nice Drawing …
Just did. No Picasso drawing at this time.![]()
