Parallel/parallel connection, night time voltage dropping and other yummy stuffsđŸ˜”â€đŸ’«
There is full sunlight at the moment. (Autumn low angle sunlight) I keep my eye on it and it’s not going above 150W at all. Sidenote: the sun is reaching only 2 panels in 45° or so, the 3rd, single panel’s 90% is in the shadows.
If this chart is true then my battery is definitely not on 73% with 13.49V. More like 92-95%. Am I right?
That will depend on if you’re battery is under load (and how much load), i see the chart is for a battery that’s not under load (resting voltage) SOC cannot be calculated by voltages alone. (note the charging voltages)
Have a read of this below.
https://www.victronenergy.com/media/pg/SmartShunt/en/operation.html
@toffifee
if you have two MPPTs I would suggest using both, each with two panels.
There are two version of Renogy 200W panels: 20V and 38V.
I would put 38V panels in parallel for better shadow performance and 20V panels in series.”, higher start voltage.
I wouldn’t take much notice of that chart. The SOC of LFP batteries is difficult to judge by voltage alone.
No, that’s not gonna happen, because it’s an RV so no place for that in my storage area. And no willing to drill more, using more cables, no more extra weight, etc. Will go with the bigger MPPT as soon as it arrives and maybe (not 100% decided yet) buying another of the same panels. And that’s it.
Done reading it. But understand very few of this.
I understand.
There is lots to learn best to do it in small bit’s that way most will stick. For now get to know how you MPPT work’s and understand all the stages of charging ect then as you need to you will pick-up the rest, it will take a bit of time but you will learn and more importantly understand.
Lots of good people here always willing to help.
Good luck :+1:
If you want your SOC values to be approximately correct, the values in the shunt must be entered correctly. With the winter sun at the moment, you will hardly get any full charge phases anyway. But these would be important for your shunt to synchronize to 100%.
A little adjustment is still necessary and other yummi stuffs :wink:
Are the shunt and Mppt connected in the Smart Network or do they both work alone?
Yes, a super smart team is helping me out here and everyone is very patient. I am very thankful for this.:blush::pray:t2: However I am very much a handly-woman I know it’s not easy to push some info to a woman’s head who has lack of knowledge of any kind of electrical stuffs. But I am trying my best without any physical help around. It was a stupid mistake that I’ve made to install the cables in the wrong way on my SmartShunt.
(For this discovery the award goes to
 :drum: :drum: :drum:
 Steffen :pray:t2: :pray:t2: :pray:t2: :blush: )
I hope that no more mistakes will pop up.:face_with_peeking_eye::grimacing::smile:
Don’t really understand (yet) those voltages, ampers and watts but I did everything alone and this is not an easy task to do. I collected the infos from the net, tried to learn everything that I had to learn to understand what I am doing (for example it took 2 weeks just to learn about the right thicknes and types of the cables), then I calculated my system, built it and made it work
even if I did this mistake with the SmartShunt’s wrong cable connection, I am still very proud of myself.:muscle:t2::upside_down_face:
:upside_down_face: Thanks
 but now
 the blue lights are :expressionless:
You could, for example, place a foldable solar cell behind the windshield as sun protection if the vehicle is standing around anyway.
that’s 45° and a small + of solar power in the winter sun
Yes they work together. Yesterday I deleted my precvious network but today after I turned the SmartShunt around I’ve connected them into a network again.
The battery was never charged by me. I don’t know what was its voltage originally. It’s new and just realized today that the factory suggests to charge it to 100% BEFORE the first installation. Not sure what to do with this info because it’s already installed.
What will come next are the low outside temperatures below 5°C
 also in Denmark.
Then your battery will stop charging because the BMS blocks
 even if the sun is shining
 even the little curtain won’t help. It simply gets too cold in the storage compartment.
Looove this idea! Will do that.:star_struck: However I don’t love that you’ve just spent my money with this idea.:joy:
But
how the hell to connect it to my system?:thinking: Through the unused part of my DC isolator maybe? A cable from the front windshield to the DC isolator :arrow_right: to the MPPT :arrow_right: to the Lynx distributor :arrow_right: to the battery? Or how?
That depends
 the best would be a small separate Mppt that would also be in the SmartNetwork
 which is only supplied by the solar cell
 there are many different versions.
The car is heated 24/7. I hope that the storage compartment won’t reach 5°. The curtain is for the curious eyes. You all know that a system like this costs of a half pair of kidneys. I don’t want them to see it.:grimacing:
 is 1 kidney
 :thinking:
How is the car heated 24/7?
We can agree on that.:smile:
A 2kW Diesel heater. I’ve just installed it few weeks ago. Best solution ever. Cheap and if you connect it on the right heating pipes in the RV then it heats up the warm water tank in the Truma as well. And the diesel heater doing it without using Truma itself or using gas.
Sounds like a runaway vehicle
 :shushing_face:
Hide the location
 and continued success
 :+1:
