hi,
I have been thru 8 victron 115watt 6 amp panels (SPM041151202 115W-12V Mono 1030 x 668 x 30mm series 4b) and i test open circuit at around 21.5volts before connecting one at a time to my 100/50 mppt which is connected to 2 *170amp lithium batteries in parallel.
Once the controller kicks in , the voltage is reduced to around 16 volts, tho i can get 4 to 6amps out of them. But that voltage doesnt get me up to 14.6 volts to charge batteries, only about 13.2v.
when i disconnect panel and retest open circuit i only getting around 20v, with the last panel was 19.4 volts on the mc4,s , and by connecting the mc4,s together , i measure 5.56amps with clamp meter.
I have mc4 to anderson lead adaptor and its only like 1m long, so voltage drop over cable length should not be an issue, and i have had portable panels connected on 6m leads with no issue, which i again tested a 200watt blanket and it was giving 18.5 to 20 volts. i also tried my other 100/50 mppt with same result and also a 25amp dcdc.
Seems like after the panels first load on it, it never gets back the ovc from brand new and only get about 70 to 80 watts from panel.
I had a frame made to take three of these panels and be on the roof of my car to run fridge, starlink and i have 2 routers and a security camera, plus cerbo, and it always draws atleast 1.2 amps.
I am in touch with dealer and gave them access to my cerbo, but i think they are also stumped.
anyone have any ideas or solutions please
thanks
