Only 4kw discharge on a 5kw multiplus
@JeroenSt To get more power out you need to change the Grid Code from G98 (as shown below) to G99. And then export to devices that have a power factor of 1, which most resistive devices are.
You will need a password to do this and you should have approval from your DNO.
I live in the Netherlands so the grid code is different.
