It keeps drawing power from the mains
Battery is full
There is a lot of sun (southern Spain)
Inverter = EXTERNAL CONTROL
I have installed ESS AssistantPurpose: OFFGRID → battery use only, mains connection in emergency
The setup:
1pcs Victron MultiPlus-II 48/5000/70-50,
1pcs Cerbo GX MK2 and display,
2pcs Pylontech US5000 batteries,
1pcs Victron SmartSolar MPPT (DC-coupled PV)
Power in 1-phase (32A) AC
OUT 1 = home/house installation
OUT 2 = empty
Your system is not offgrid, since it does have a mains connection. You dont want to draw power from it, but thats a completely different thing. Did you follow the ESS guide
Hello Nick
I did read it, but I can’t find the problem.
I removed the ESS again,
but it keeps drawing power from the grid and even charging the battery from the grid.
The MPPT has sufficient solar power but does nothing.
What is baud rate of ve can1 where the smartsolar is connected? I don’t recall the default setting but it does no harm to double check that setting on Cerbo. The correct speed is 250kb/s.
Also, it’s not normal to have both the Cerbo and the MK3 connected at the same time.
If that fails, connect the charger with a ve direct (or ve direct to USB) cable to test.
