NodeRed, Cerbo and 2x Orion XS50 - not equal available nodes
Hi Guys,
I have two Orion XS50 with the same firmware v1.08
One shows as Alternator, the other one as DCDC charger if I look at device list.
In NodeRed I use the “custom input node” and settings/ChargeCurrentLimit. This worked on my last Cerbo and these two XS`s av using, but now I can only find this setting on the one that is set as alternator in device list.
Any ideas??
Pictures:
I found the problem. One XS was set to power supply and not charger…
Once I set it to charger again I was able to change current settings.
