Node-RED and Function AC OUT 1
I have a MultiPlus-II 48/3000/35-32 with pylontech battery …
I had connected some important electrical plug on Ac out 1. So if i have no electricity, this plugs works on the battery.
All it’s ok but i like to use Node-Red to switch the Multiplus to use electrécite and not the battery between 10Pm to 6:00 (electricity it’s sheaper).
The switch works but all plugs Ac out 1 shut off…
My question it’s possible to shitch the multiplus but keeping alive AC-OUT-1 ?
Regards
If you switch the Multi off, the AC output will also be off. If you need to bypass power around the Multi, you need an external transfer switch.
Grid power normally has priority over battery power so leaving the Multi on probably does what you want without making any changes. What might require changes is to prioritize battery power at other times. If you wanted to totally ignore the grid during that period, you can switch the Multi to “invert only” mode.
Thanks for your reply.
My goal if it’s possible it’s to use grid between 10Pm to 6:00 AM.
No mode it’s possible to keep AC out 1 on ?
You need to use a transfer switch or switch on AC1 input controlled by the Cerbo relay !
But only the AC2 out will be active when AC input is Off.
Xavier
I added to my config a Convertissor-chargor 3000VA 48V 35A MultiPlus II and a ET112
I have a question it’s possible to change to this parameter by node red :
→ External control
In this mode the battery was not used ?
AC out 1 will works in this mode ?
Regards
