New GX Device - Consumption vs Grid Stats. Battery Grid Charging: 'Direct Use' rather than 'To Battery'
can you check betavrm.victronenergy.com (You can just login with your normal credentials) - there is a refreshed view of this graphs that will soon ™ be released, which is more detailed on telling the energy flows apart. See also:
Edit: Ah, you are referring to the “System Overview Graph” - well, that is something else. But you could check the beta, if these values have been adjusted as well with the changes on DESS outlined above.
Don’t mix “Consumption” and “From Grid” they are obviously not the same thing. Energy that is flowing from the grid to the battery obviously is “from grid”, but not (yet) “consumption”.
